1 - 5 of 5 Posts
...with the proper spring rate on 5th element coil.i weigh 220lbs .went to tf suspension and used the spring calc,but the rate seems high.dont know where else to look.anyone have any experience with these rear shocks??
based on the 06 owners manual (under FAQ's on the website) your spring should be 450lbs. The 5th elem works basically the same as a Swinger which is stock on an Uzzi.
Old school BMXer
I have the DHX Coil on my VPX. Although the shock really doesn't make a difference, since spring rates are spring rates. I weigh 190 pounds, and I have a 500 pound spring with a one to two turns of preload (it's been a while since I set it up).
I think you're likely looking at a 550 pound spring.
1 - 5 of 5 Posts
