Dos
it's called the DOS.jaydrunkenpee said:
it's called the DOS.jaydrunkenpee said:I don't know if this has been mentioned or not, but you've got to admit, it's a spiffy idea;
http://www.sheldonbrown.com/lasvegas/2003-show/pages/09-white2freewheel.html
Great minds think alike?eSSq said:That's nuthin'. There's companies out there what make similar devices with as many as ten (10) gears fer the back end of yer bike. 'Course, then it ain't much of a singlespeed, then, is it...?![]()
if you use the DOS, you have to use 2 rings up front. No shifting mechanisms are needed, just your dirty fingers.eSSq said:That's nuthin'. There's companies out there what make similar devices with as many as ten (10) gears fer the back end of yer bike. 'Course, then it ain't much of a singlespeed, then, is it...?![]()
ernesto_from_Wisconsin said:if you use the DOS, you have to use 2 rings up front. No shifting mechanisms are needed, just your dirty fingers.
QUOTE]
Let's say I'm a pretty boy who doesn't like to get his hands dirty (not far from the truth)... shouldn't I just ride a geary? I mean, if I'm going to be shifting gears in any fashion, shouldn't I make it as easy as possible?
I'm not a singlespeed evangelist or anything. I don't have any geared MTB's but I do ride and love my geared road bike. I'm just saying that If you're going to shift, don't be ashamed of it, just do it, and do it right.
I wonder if there will be a new race category for this kind of set up.ernesto_from_Wisconsin said:if you use the DOS, you have to use 2 rings up front. No shifting mechanisms are needed, just your dirty fingers.
Lets just say that your trailhead is 10 miles away, and youhave to ride on ass_phalt to get there. Move the chain to the tall gear, still SS. You get to the trailhead, do another adjustment, you are ready to SS with a short gear.
Pretty?? As in West Hollywood pretty? Or pretty as in backwoods purdy? I knew I should have been afraid of those comments on the SART ride.eSSq said:Let's say I'm a pretty boy who doesn't like to get his hands dirty (not far from the truth)...
Well, I did wear some FABULOUS Gordon Rush sandals to the Ahmanson on Saturday evening for Thoroughly Modern Millie.gpsser said:Pretty?? As in West Hollywood pretty? Or pretty as in backwoods purdy? I knew I should have been afraid of those comments on the SART ride.![]()
how is this philosophically any different from having a flipflop hub or more than one size cog for your cassette hub? Different areas call for different ratios. Personally, I like the idea very much, if it could be used with a single front ring. It's probably the only way i'd consider running a threaded/fw hub.appleSSeed said:haha, no doubt. I think they already make these in many different gear ranges..haha..
what a load
if you have one of these, you've officially "lost the way"
The begining of multi-speed derailleur bikes started with multi-speed freewheels. To put a multi-speed freewheel on a single speed is the philosophical equivalent of the guy who wanted to convert a Kona Unit into a geared bike. You could, but who would want to? Personally I ve never been a fan of flip-flop hubs on MTB's and in order to change the cog on a cassette hub you have to take it apart. I may be single minded, but I like the idea of one speed; one front chain ring and one rear cog or freewheel. Anything else is still a bicycle (and that's a wonderful thing!!), but it's not SS.a nice cake said:how is this philosophically any different from having a flipflop hub or more than one size cog for your cassette hub? Different areas call for different ratios. Personally, I like the idea very much, if it could be used with a single front ring. It's probably the only way i'd consider running a threaded/fw hub.
What I meant was the idea of changing the gear ratio with a double freewheel and matching double chainring to keep the chain length the same. I know some follks have figured it out on their own, but this is the first OEM set I've seen.c0jones said:In the mid-70s I had a Schwinn (Typhoon, I think) with a 2-speed coaster-brake hub... no shifter... just back-pedal to switch to the other gear.
The earliest 2-speed hub was made around 1903
C Jones
