Has anybody ever considered or used those spray on liners (or something similar) that are made for truck beds to protect a frame? I have a Carbon frame and inside the yolk in front of the rear tire the mud/rocks spraying up have chipped away the paint. It has not damaged or exposed the carbon at all but unless it is protected it will eventually. I thought about taking the wheel off and after covering up the rest of the frame and taping around the blemish area I could spray it with that stuff, make it look clean almost like it belongs and then after it dries covering it with a clear plastic framke protector vinyl sticker or someting. I want to use the spray as they are water proof and that way if I chew through the vinyl I know that it will have something else there that is tough to take some rock spray before I replace the vinyl again. Thought?
