1 - 1 of 1 Posts
· Registered
I browse though the pictured in here and I notice many of you use the same lines I do; stainless steel braided.
Only think is, if you aren't using Goodridge then chances are you are going to get rust after a while at the connectors.
Take a few minutes to undo the line at the lever and slip a couple of pieces of heat shrink over them, squeeze the lever until you see fluid just bubble out and reattach. You won't need to re-bleed the system.
Heat 'er up and you are weather proof.
1 - 1 of 1 Posts
