I just got a pair of Deore LX ST-M580 dual control levers on the cheap and I'm trying to figure out if I want to put them with a top-normal rear derailleur or a bottom-normal.
It seems to me like I would want to be able to shift two gears lower at a time for things like climbing rough hills. So my intial instinct is to go with top normal. However, the default setup in the Shimano manual is with a bottom normal (allowing shifting to higher gear by twos), so there must be a reason.
So I ask all of you: why would I want to run a top-normal with this set up and why would I want to run a bottom-normal with this setup? Experiences? Theories? Thanks
