If you get Avid BB7's they're about the most reliable disc brakes on the market. Comparable to rim brakes, but the pads don't last quite as long. The upside is they don't wear out your rim and they work in the wet.
Then you DEFINITELY want discs.Snagged7 said:I'm trying to stay away from having to do a lot of maintenance with the brakes.
You = wrong.vanamees said:Rim brakes, mechanical discs = previous century.
This gets talked about a lot. Do a search.Snagged7 said:I'm trying to stay away from having to do a lot of maintenance with the brakes. I don't know a lot but figured the rim brakes would be much lower maintenance than disc brakes would be. Is this a true assumption or do I have it wrong? Also, what are the pros and cons to both setups?
Buying a new bike. My old bike is a Trek 820 and very old so it's time for a new, better one.Wildeyes said:Are you buying a new bike, or are you riding something right now that you want to upgrade?
If you are buying new, I think discs are pretty much a no-brainer. There are few new complete builds that even come with v-brakes these days, as most mid to high end forks and frames are now disc-only.Snagged7 said:Buying a new bike. My old bike is a Trek 820 and very old so it's time for a new, better one.
I did a quick search on this topic and didn't come up with a lot. I didn't notice the FAQ section, I'll have a look at that. Thanks for the info/advice thus far.
