While riding with another Prophet owner, he complained that he could see the seat tube and seatstays move side to side relative to each other. He claimed that the bike did not do this when it was new.
Now I seem to remember that my Prophet has always had some side to side movement between the seat tube and seatstays from the very first test ride. I do not understand how you would not have this motion with a single pivot swing arm. Any small amount of flex at the pivot will be amplified as you travel up the seat tube. When the seat tube passes between the seatstays the relative motion between the two would be apparent.
So if you own a Prophet and you are riding along a flat section of single track sitting in the saddle and look down along the seat tube, do you also see some side to side movement of the seat tube relative to the seatstays?
ZIT30/34
ZIT30/34
