I have a Race Face Deus crankset and an XTR 2007 front derailleur (e-type). I installed the spacers as noted in Race Face's instructions. 1 on the non-drive side and 1 on the drive side plus the e-type front derailleur bracket. The instructions clearly state that the spacer on the drive side must go against the bottom bracket shell of the frame and then the front derailleur bracket should go on (followed by the drive side bottom bracket cup). I did this and what happened was the smallest chainring on my crankset (24T) was rubbing up against the XTR derailleur bracket when I would screw in the crank bolt. Obviously this chainring should not be hitting the derailleur e-bracket. But I followed the directions for a 68MM BB shell with a E-Type FD. What do I do now? Thanks for you help.:madman:
