My Prophet 1000 has had a rear brake (Juicy 7) issue from day 1: the caliper appears to be slightly to one side and gives plenty of pad clearance on the outside but touches on the inside face of the disc. The dealer has tried 3 times to correct this but I think all he has done is the screwdriver forcing the pads back trick and the Avid adjuster bolts.
The dealer said it was normal and would go away after a couple of rides. Well its still there.
It looks as if I could put a thin spacer in the mounting bolts to centralize the caliper more accurately. Do these kits exist? Has anyone else had a similar problem with Prophets?
Thanks.
Thanks.
