1 - 10 of 10 Posts
Discussion Starter #1
Here is my latest build. It's my proof of concept build for the SickLines “Do-It-All” Bike Build Guide. It actually weighs in at around 34.1 lbs to about 36.5 lbs depending on tire and tube/tubeless choice. I'd put the build spec in the thread now but I don't want to ruin the surprise.
The article will feature all of the parts that I've chosen for the build. I'm giving a little commentary on each part as well as showing off lots of pictures.
Link to proof of concept article - https://www.sicklines.com/tech/proof-of-concept-do-it-all-bike/
Lets see a picture of the bike on an actual scale to belive the weight.
If it's a "Do it all" bike the gear range is limiting to alot of trails.
Good looking build.
-> SickLines.com <-
Good looking build.
http://www.sicklines.com/tech/proof-of-concept-do-it-all-bike/
There is the weight page in there as well (page 6).
You are correct about the gears limiting but a DRS or similar guide can be used instead if you wanted more gearing.
My bad I didn't click on the little picture links yesterday. Figured maybe those weights were "published" not true actual weights.
That is such a sweet bike. If I'd known it could have been built up so light I never would have bought my 6.6. This is definately on my 'list of bikes to own before I die'.
Banned
I'll bet that Saddle saved you at least 5 pounds.
Can you even sit on that thing?
Sweet bike. Love the Balance w/a 66.
Discussion Starter #10
LOL it's a common comment. It's actually not that bad to sit on at all. I'm used to running saddles with thin padding so it's not bad to me. It has a lot of flex so it doesn't have a harsh ride really at all.
1 - 10 of 10 Posts
