like the others have said, the standard pbr comes with 138mm of space between the clamps, the "xl" version has about 163mm.
not sure how tall you are, but i am 6"1 with VERY long legs and i run the stardard clamp width pbr (130mm travel) and i have plenty of bar height (i also run a flat bar).
my custom quiring ti ss has a 105mm ht length and a king headset (32mm stack height)...total of 137mm of stack. perfect.
i run the project 321 steerer....Jake makes a great product....support him. i am probably going to order a new p321 28h lefty hub to lace to a edge 29er carbon rim. call ya soon Jake!!!
also, i'd suggest cutting the crown race of you headset so you can seat it by hand. it makes things much easier. and, i'd also suggest a cane creek headset or another brand that has a compression ring. my king headset gets loose after every ride. i had to add a azonic headlock, and that keeps things tight.
crown to axle for a pbr 130 is 500mm unsagged. the 140mm pbr should be 510mm unsagged.
the pbr is a great fork. i only have a couple of rides on mine and i already like it more than the 2010 fox f29 rlc fit i was running.
here is a crappy pic of my set up;
<img src=https://farm3.static.flickr.com/2769/4266117505_056d68f572_b.jpg>
