I just finished a Weyless XP build and the frame came with a 5th Element Air rear shock. I am trying to use the pump that came with my Reba front shock, but it does not seem to work. There is no pressure reading or anything. I pressed the valve on the shock to ensure that there is air in it, and there is. It almost seems as if the valve on the shock is to short to connect to the pump. By the way, I serviced the front shock witht he same pump and it worked fine. Anyone hard of this????
