I'm just installing these brakes on my bike, and they're feeling spongy. The lever also has to move a lot before the pads engage the rotors. I've bled the rear brake because it was the worst, with maybe negligible improvements. I've pushed about 20 ml of fluid twice through the rear brake (how much is in there anyway?) and only saw bubbles when first starting out. A ton of fluid came out of the caliper when I removed the bleed screw from it as well. The second time I pushed more fluid in there were maybe very tiny bubbles in the syringe.
I've bled SRAM brakes before but this is my first time with mineral oil. SRAM has about 30 more steps but the syringes are much higher quality and the process of pulling on it to create a vacuum and get more air out gives me more confidence in being successful.
I'm using a single syringe and a screw in cup on the lever with these TRP brakes. I have pumped the lever multiple times and held the lever down for 15 mins or so multiple times while the bleed port on the lever was open with the cup containing fluid.
What am I doing wrong?
