Wrong size ? Is the suspension sagged ? Have you discussed this with Titus ? 1-800-85-TITUS
Think that has anything to do with it ?climb3r said:Richard's Bikes, the bike store I bought the frame and build put a 100mm fork on the frame, even though Titus recommends an 80mm fork.
1. You can't use standover height as a valid measurement.climb3r said:I've called and emailed Chris at Titus and he's investigating. I've measured the top tube and the seat tube, and they appear to be the right size for the xx small Racer X.
The standover is supposed to be 24.65, but I don't have that standover anywhere on the frame, measuring from the top tube.
Umpossible!!!! nmAZ.MTNS said:Think that has anything to do with it ?
1. standover is overrated (as Ken pointed out)climb3r said:The reason I want standover clearance is because I'm a complete beginner and would like ton be able to get off the bike quickly if there's a problem. The bike has 26" tires, and Richard's Bikes told me they put a 100mm fork because the Titus specifies that the bike has to have 100mm travel. Richard's also told me that the difference between an 80mm fork and a 100mm fork is less than an inch.
I not only have no standover, the top tube is pressing against my crotch, so I'm not sure what to do.
well son-of-a-gun....didn't know the RX turned into the Xclimb3r said:Yep, I I went to bike shop and my inseam was measured just like shown on your image. My inseam is 25" and 26" with regular run of the mill sneakers.
I bought Racer X because all bike shops recommended it for me (Pivot didn't exist yet).
24.96 is the xx small measurement for the Titus X. The xx small standover for the Titus Racer X is 24.65 (http://www.titusti.com/racerx_le.html#geometry).
When I measure standover according to picture on titus website, I get 28" standover; that's 2" over my inseam.
I agree, I think it's the 100mm fork, so I'll have to get 80 mm fork.
You can just have the travel reduced, I can't think of any mainstream fork that you wouldn't be able to. :thumbsup:climb3r said:When I have some money saved, I'll buy a 80mm fork.
How tall are you?climb3r said:Thanks for the advice and help. I will ride the bike, although I'm afraid because I have no standover. I'll set the fork down to 80mm and give it a go.
Surprised it took this many replies before someone suggested platforms.....mudlover71 said:Or.....you could get some stripper shoes. I've seen some chuck taylor lookalikes that have like 5 inch soles....:thumbsup: :thumbsup: :thumbsup: :thumbsup:
If you can set the fork to 80, whether through spacers or some sort of external travel adjust features, you now have an 80mm fork, no need to go get a different fork. It will affect the AC length and should give you more standover.climb3r said:Thanks for the advice and help. I will ride the bike, although I'm afraid because I have no standover. I'll set the fork down to 80mm and give it a go.
