I recently went to 1x9 and noticed some problems with the chain staying in the lower two gears while under pressure. I later replaced the chain with a PC-991 and removed 4-5 links. I also followed (or so I think) the directions on adjusting the rear der (Shimano Deore).
Now, the chain doesn't want to stay in the lower 5-6 gears while under pressure.
Any suggestions? Should I play with one screw (B-screw, top screw, bottom screw) at a time or?
