I`ve got some problems installing the Shimano XT-M780E front derailleur on my Yishun FS frame (FM169, should be the same frame as Hong Fu, Deng Fu and I-PLay FS-frames). The hole through the bottom of the frame that the gear cable runs through doesn`t match up with the wire connector on the derailleur, it looks like the hole is a little bit too far back compared to the the derailler so it`s impossible to connect the wire in the way it should be routed through the derailleur.
Hs anyone else experiencd anything like this with the chinese S-fames?
