Has anyone else noticed marks on the inner surface (where the shock bolt passes thru) of the reducers from the shaft eye of their rear shock?
I've just pulled my Fox Float out of my '03 Enduro to swap shocks and noticed that there are thread marks on the inside surface of the reducers where it looks as though the threads on the rear eyelet bolt have been in contact with the reducer...
I was thinking it was either from a very hard landing with not enough air pressure (I run 200 - 220psi and weigh around 210lbs) OR just a normal wear pattern after 12 months of use in very dry conditions. As several people have mentioned in other threads, they are made of soft aluminium, so I guess they are meant to wear out eventually.
Any thoughts? Thanks...
