Hi,
So, I bought Shimano Deore XT front derailleur from Wiggle (https://www.wiggle.com/shimano-deore-xt-m8025-front-derailleur/?sku=5360710322) to upgrade my previous Shimano front derailleur.
I have it now installed, but it is not as planned. The height is now optimal with respect to the largest chainring. However, the problem (see the attachment pictures) is that the clamp is now over the lower screw hole for mounting the bottle cage; lowering the derailleur results in direct contact with the chainring and rising results in too much distance from the chainring (and also for additional problems with the bottle cage).
The installation, as shown in the pictures, works somewhat. The derailleur seems to stay in place, but given that the installation is done partly by using gorilla tape feels ... well not satisfying. Also, the clamp is not optimally tightened to the frame (even with the gorilla tape and all
), because of the factory pressed/molded washer (or whatever) in the frame around the mounting hole, making the installation surface uneven.
Summa summarum: Is there any solution to fitting the derailleur into a different spot on the frame (the previous derailleur was underneath the mounting hole)? Is there any, i.e., adjustable clamps available in this situation, for example, from problem solvers (https://problemsolversbike.com/products/shifters-derailleurs) etc.? Any other solutions come to mind? Or do I have to get a new derailleur that fits the frame?
Thanks to all!
Thanks to all!
