Problem with CK hub-Fox-Floating disc,
638 Views 2 Replies 3 Participants Last post by  mtnbiker4life
Hi,
I ride with a CK ISO front hub,i have a Fox RLC 2010 and Hope X2 race brakes.
The problem is i can not use a Hope Floating disc at the front because it hits the forkleg.
So i ride with a regular Hope disc and its very close but this one does not hit the forkleg.
I prefer riding with floating discs rear and front,so is there a solution for this problem?
Some of you have the same problem?
1 - 3 of 3 Posts
it's overlapping manufacturing tolerance.
IIRC Chris King makes some exle ends or adapters or something to change the hub offsets and move the rotor mount inboard. ideally you would want to redish the wheel after that.
The majority of the problem is Fox. I have both a 2011 Talas and a 2010 RS Rev.....same wheelset and the rotor almost touches the Fox lowers but has plenty of clearance on the RS.
1 - 3 of 3 Posts
