1 - 2 of 2 Posts
I recently removed my cassette to clean mud from between the gears. When i replaced it my tire rubs up against the frame. is it a problem with the way i replaced the set, or is it a problem with the axle?
Old man on a bike
I can't see what taking the cassette on and off would have to do with your tire rubbing on your frame...you sure you put the wheel fully in the dropouts before clamping it with the quick release (or tightening the bolts if that's what you have)?
1 - 2 of 2 Posts
