Grr.
I pulled my cassette last night to clean all the sprockets etc. It was a little stuck on the freehub body due to the alu shell, and I inadvertantly removed the freehub body from the hub. No big deal. I didn't lose anyhthing, and it just presses back on...
Except when I put everything together and clamp the QR skewer down with the wheel in the frame, the freehub body wont freewheel. The all-important spacer is in between the driveside hub bearing and the freehub body, and everything works fine with the wheel off the bike. It seems as though the driveside spacer is rubbing on the outside edge of the outside freehub body bearing, causing drag, which is obviously exaggerated when the qr is closed. This baffles me. I've not moved the axle or any bearings and, like I said, the critical spacer that often causes this is definitely in place.
Dissassembly and reinstallation didn't solve it.
The only thing I can think off is that I need to be a bit more forceful in pressing on the freehub body. Maybe it isn't quite properly seated hence the drag I'm experiencing.
Any suggestions?
Any suggestions?
