Have you confirmed if Push can work on this Triad? I would make 100% sure before you decide. Do not assume with this particular shock.
When you say "extra travel" are you referring to the 120RL or the rp23? I'm having a hard time understanding what the heck your trying to say in your posts.gigabyte772 said:Well I just got the rp23....
Will have Fri...
He said he had to have a lbs install it to keep the warranty intack with the frame. Will the extra travel be a problem and what do people suggest if I should get someone to remove the spacer in the front shock float 120 rl to make it 140?
Thx Jerk....
Look jokey....learn to write properly and it would be easier to understand.gigabyte772 said:Well if you understand English you should be fine as I kept rereading my post and seems fine... I am talking about the extra 1/4 inch travel that the rp23 will have over my Triad... As far as removing the spacer in the front what should it cost a LBS to remove?
You and I have been talking a great deal lately on this issue. I'm gonna say your head angle will be a little steeper than most would like on this bike. The 140mm fork will be an absolutely perfect match to the nearly 140mm rear. You're raising the rear nearly 20mm. The SJ FSR is an extremely low bike, and maybe too low IMO...pedal strikes are way too common on one with a 120mm fork. Getting the bike to a 140/140 attitude almost seems like where this bike should have been designed by Spec.gigabyte772 said:Thx and I saw the directions at Fox's website and I can bleed my brakes and replace the pistons in my brakes but a full fork scares me a little. I usually mess something up first and then know not to do that in the future but I would like someone else do this. Wil it ake a big difference if the spacer is removed. I do not do high jumps, maybe 1 to 2 ft drops and weigh 170 less accessories...
