21 - 40 of 52 Posts
emu26 said:
Oddly enough, it too qualifies for the ugly awards. Note my obvious concern about heat with this model, triple P4
Apologies for the out of focus shot
I almost fell off my chair when I saw the mint box! Great minds must think alike! They hold a switch and buck puck with plenty of working room.
I'm ashamed to post these here, but this is what happens when you don't have proper tools and two days before a special night ride! JB weld is my friend or NOT! My new years resolution is to work on my patience.
Now you know what all my model cars and airplanes looked like when I was a kid.:D
I made a double set that looks the pretty much the same with 25deg lens for floods on my bars. They may be ugly, but they work perfect.
whatever works? I use my own build light (lighter weight, brighter then OEM and lower profile on helmet). and the best is the beam pattern I like. and I use them if there is no chance of rain. yes, I don't trust my light to be weatherproof. I have 800L, Trinewt, two NITErider HID, and 400L and the big 30W HID. I perfer my own led lights bc of the beam pattern is so much better then any of the OEM lights offers.
Resist said:
I notice a lot of people use this same metal tube style design. The Amoeba comes to mind. Where are you getting them?
Resist - that's the Acesalot DIY design. Simple, raw materials are easy to find, and building doesn't require a lot of fabrication tools. They're all self-fabricated from Achesalot's instructions, modified as each builder sees fit.
His website is here: http://bikeled.com/
"Currant-sauce" helmet-light
After blowing-up my nice-but-somewhat-expensive MaxFlex3 driver, I cobbled-up this cheap 'n cheerful LM317-based 'current-source' driver, just for a laugh. Hence the title. Surprisingly enough, the LM317 seems to be driving the MC-E just fine, though it's probably woefully inefficient. Even so, with an 11.1V LiPo battery, I've seen over 9-hrs battery-life so far, and it's still going strong....
So here's my fugly helmet-light; it's just a shortened version of my older Dinotte-style light, that I fried a few months ago. If anything, it's even uglier than ever now ...
You can do reasonably well if the battery/led volts are appropriate (so not much power is burnt off in the driver). I think 3 leds in series off 11.1V would work well. 2 is not so good.
Whats with the diodes?
Thanks znomit.
Hee hee! Well I'm a hopeless newbie, but I'm always keen to learn. So as a bit of an experiment I just wired up 5 zener-diodes in parallel, on the input-side of my circuit. The intention was to protect the LiPo (nominal 11.1V) battery against over-discharging (below 8.8V or so). But I'm embarrassed to say it doesn't work, 'cuz the 'knee' resistance of the diodes is so high that no current flows at all. So those zeners are just shorted-out now, in order to make the thing work.
By the way, I'm still awfully curious how to do simple battery-protection circuit? Maybe something that beeps when the battery voltage falls below a certain threshold. That would be useful I think.
I'm not sure how the pro's do it (fellow electronics noob here), but I found a neat battery monitor circuit that can be modified using different resistors to create a high and low voltage limit indicator here. It is very simple and just uses a couple comparators with some resistors and pots. Seems like it would be simple to change it to actually cut power based on a high or low voltage condition. I ended up not using it, but I did test it and it seemed to work OK with my 18v battery. You can also buy pre-made battery protection boards from battery-space.com.
My fugly light
Here's my light. Let's get to the pics, shall we? The 1st beamshot is the light I built driven at 1A, the 2nd is a 25W halogen setup I had purchased a while back as a comparison. The white shed is 60' away and 10' wide. BTW these pictures look quite a bit darker than it looks in real life. The 25W halogen set up makes plenty of light for riding, while the double-triple LED makes more than I need.
The light body is a 30mm cantilever scope mount. The heads are 1.5" OD 1.384 ID aluminum pipe. The heat sinks are 1.5 OD bar stock shaved down on the table saw to fit snugly in the back of the heads. Everything was brazed together.
The guts are two bFlex drivers, one for each head. The bFlex boards are nicely cradled in holders that Don mailed out to me (Thanks Don!). The bFlex units are controlled via momentary switches mounted on the grip. They are connected via telephone handset cable. The LEDs are Cree Q5's. The optics are Khatod medium and narrow.
The mount is a Cateye mount with a bit of Weaver rail bolted to it. The scope mount bolts to the Cateye base plate.
yetibetty said:
bwilli, it's not really that ugly infact I quite like the "means business" look but it does appear from the pics like you've got a lot of weight going on there.
Is it as heavy as it looks?
Thanks! I posted it here 'cuz the build quality is not quite on par with most of the stuff on here. The cuts aren't straight. The brazing is ugly. The switches are potted in hot melt glue. It has a lot of... character.
Including the mounting hardware it weighs just under 300g, so it is a bit heavy, but I don't really notice it when I ride. It also does OK with heat management (I think?). I can run at 1A in still air for about 9 minutes before it gets to 60C (this is where I turned it off). It reaches 45C in about 20 minutes at 350mA and holds there. The entire assembly heats up, all the way to the mount.
The learning curve on this whole project was pretty steep!
First off sorry for bad pics, was taken with my phone.
The other day I played around with some CHEAP 5mm high brightness LED and slammed a light together with them. It has 19x 5mm LED running straight off 3x AA batteries. Housing is plumbing pipe pieces. I must say it gives more light than I expected. They are bright enough that you can not look straight into them from a 1m away. I have a 20w halogen down light i compare it to and is not too much worse, the beam is just very narrow. I mount it on my helmet tonight and while try it when I can. Cost wise, well not sure as most of it was stuff around the house. I know you can het a 25pack of 5mm led as DX for $2.60 I think.
HuffyPuffy said:
Holy PVC Batman! The last time I saw that many lights was when the mothership dropped me off :D
The 5mm LEDs are a bit underrated, well really they can't hold a candle to a high power LED, but with that many you must have a nice flood light.
Actually not a nice flood. The standard 5mm LED is a very narrow angle. I think is it something like 10 or 20 degrees. It is a ok spot. Will try to take some beam shot tonight.
JimZinVT said:
Here's a very simple battery warning circuit I bookmarked a while ago, but still haven't got around to trying.
JZ
I was starting to consider allowing some scope creep on my 2nd and 3rd lights and putting in a low battery indicating LED. (I got packs from batteryspace that have the protection board on them already)
Then I got to thinking. Dangerous, huh?
My Li ion drill runs at pretty much full power and then dies suddenly in about 5 seconds.
Are my Li ion lights going to do the same? I thought that was one of the characteristics of Li ion - they give full power right up until they shut down.
If that is the case w/ the lights, there's not a lot of point to a warning light because I won't be able to do anything about it anyway. I'd be better off just learning the run time I get on full power with a full charge and just monitoring ride times.
But then I wondered if the power coming out of the pack does actually slowly decrease such that a warning light would provide benefit, maybe let me know in time to switch packs or flip over to Low to conserve.
I built a pack using parts from Batteryspace and am using the "fuel gauge" that they sell. The gauge has 5 LEDs on it. All 5 are lit up at full charge (~16.8V). The number of LEDs lit goes down as the battery is discharged. It goes to 3 LEDs before the PCB shuts the battery down at about 11V. You should have enough room to hack together a decent warning circuit!
Just be sure and share anything you do! :thumbsup:
21 - 40 of 52 Posts
