2008(?) ASR-Carbon Medium frame w/RP23 shock 2160g (4 1/4 lbs? More like 4 3/4 lbs)
Shimano crank bearings/bearing holders/plastic spacers/plastic center cover (included in frame above)
2007 Lefty Speed Carbon SL shock 1250g
Custom made CF/Al 1 1/8 to Lefty steerer adapter 125g
XTR M975 disc brake levers and calipers (tuned)
Scrub Components 160mm front rotor (56g)
Hope Mono Mini Pro 140mm rear rotor (58g)
Syntace F99 Ti bolt 120mm stem
Schmolke SL 560mm flat bar (97g)
KCNC BE1 bar ends (48g)
ESI race silicone grips
Sram twist X0 shifters w/al. clamp bolts
Alligator I link shifter housings
PowerCordz shifter cables
Crank Brothers Cobalt SL headset (65g)
Tune Gum Gum headset starnut with carbon cap and al bolt
5mm plastic steerer spacer
XTR M970 175mm crank arms (335g)
Extralite Octaramp 44 and 30t chainrings (2x9) (86g)
Aluminum chainring bolts/spacers, etc...
EggBeaters 2Ti with Ti short axles (173g)
Campagnolo Record Ti Compact braze on FD
Parlee 34.9 carbon FD adapter/clamp
KMC X10SL Gold chain 106 links (228g)
'08 Sram X0 medium cage RD with carbon pulleys and carbon inner cage plate (173g)
Nino Ti 11-34 SL cassette (178g)
Tune SpeedNeedle Alcantra seat (85g)
Tuned (mildly) Yeti ASR-C seat clamp assembly (195g - ouch! I`m gonna fix this one)
No Tubes ZTR Race 7000 Lefty front wheel including Lefty axle bolt and extraction cap (570g)
DT190 rear hub/DT tuned centerlock to IS disc adapter/DT Revolution 2.0-1.7-2.0 spokes/al nipples/ZTR Olympic rear rim 32hole (722g)
Yellow tape and Olympic valve stems in both front and rear wheels
Tune Skyline rear MTB bolt on skewer (13g)
Continental SpeedKing Supersonic 2.3 front tire (456g)
Continental RaceKing World Cup 2.2 rear tire (480g)
No Tubes sealant in both tires (3-4 ounces)
Currently 19.3 lbs. Shooting for 18.5 lbs. Coming soon!
