1 - 20 of 26 Posts
Fo' Bidniz in da haus
There are some really cool single speeds out there now under $1000 that will give 95% of the ride of bikes many times that price. Hard to not consider them. As such, I checked out a couple at my local shop....felt great but as expected not light. I am curious if there are other weights floating around you wouldn't mind posting for completeness.
21" Redline Flight 29er = 27.3 lbs
19" Kona Unit 2-9 = 27.1 lbs
both of these looked very, very nice by the way.
I believe my almost stock Inbred 29er was about 26 lbs or a tad under
(should have weight the monocog 29er they had too)
Jamis Exile 29er = ?
Haro Mary = ?
Raleigh XXIX = ?
My 18 inch Karate Monkey weighed 26.5 lbs. But I am making a few modifications and waiting on a few parts...it might actually be heavier when I am done. It is all about fun and comfort though....
Discussion Starter · #6 ·
Fast Freddy said:
do you want weights of custom built bikes? Like my Haro Mary or Niner One9 - as I bought framesets and built up from there....
FF
my intent was to get stock complete bike build weights as those are what we all have access to but of course, in the name of fun, post away.
with the builds all so similar across the sub 1000 complete singles, i was curious if there was a similar weight across them or if one of them by chance is considerably lighter is all.
Just hit it with speed
FoShizzle said:
wow...that sounds lighter than i would have guessed for sure
Yea I agree when compared to the others. They hung it up like you would to weigh fruit in the grocery store. :D At the time I was a little surprised thinking no gears ha! its gotta be light. After hearing other weights and compiling a list of current parts and potential new parts it sounds about right. Through a spreadsheet I can account for about 21 lbs of that, but have no idea of the bolts, cables, tubes and so on. After looking at the parts I'd like to put on Thomson seatpost/stem, king headset, MAYBE carbon bars, the savings in weight compared to what I'd have to spend is absurd. I'd rather save my money and buy a decent used road bike or take a weekend trip to VA or week trip to Pisgah than save 1 pound. I lost about 200 grams in switching from SPD v EggBeaters and ditching the Bontrager Select saddle to new Serfas that saved another 200 grams all for less than $100. At this point I am probably only going to upgrade as things wear out or if a drastically light, cheap and new product comes out! The ratio of 4 grams saved per dollar spent I'm happy with but I just don't see anywhere else I could make those savings!
Don't be a sheep
FoShizzle said:
huh? these are sub $1000 bikes....what do you expect, regardless of wheelsize?
I'm just not seeing much value in these niche bikes especially with these very pedestrian steel frames and mediocre parts spec.
That is funny stuff...
Rivet said:
Sweet, fully rigid singlespeeds that weigh 3lbs more than my geared FS, where do I sign up. :rolleyes:
but makes a very valid point. My xl ss Soma Juice weighs 23.5 lbs with a WB bw.8 fork and pedals. Not crazy light but @ 250 lbs neither am I .;)
Cheap and heavy, i mean upgradable, Bikes
I have a Unit 2-9 that I am currently upgrading and am glad it came heavy. I would rather buy a bike that is cheaper with heavier parts that I can ride until I decide to upgrade. The other option is buying one for a lot more money, and though it will come with lighter parts they still probably won't be exactly what you want and you'll end up upgrading anyway, spending more money while not saving much weight. Plus with the market for used parts you can't come close to recouping what the stock semi-lightweight parts were worth. Buy a bike cheap, spec it out exactly how you want it over time, and you still have something to ride in the meantime.
And I wouldn't give up either one to have your geared FS...I suspect you wouldn't want to trade either......
Not trying to incite an argument here, but I don't understand what you are hoping to achieve with a response like that.
Powered by ice cream.
Enoch said:
My Zion came in @ 24.8. I could knock some weight off easily, but it is very durable.
Here is a link to the original post with build specs http://forums.mtbr.com/showthread.php?t=259811
Fo you might as well go ahead and buy a frame only, you will eventually upgrade it anyway.
Agreed. The Zion rides extremely nice. Between it and El Comandante, I honestly think I prefer the ride of the Zion.
Plus for the price you piece together a nice bike for under $1000 (rigid)
I also don't see how you can beat the performance of the pricepoint Inbred:
http://www.pricepoint.com/detail/14574-175_ONO295-0-Search--/On-One-Inbred-29er-Bike.htm
Don't be a sheep
FoShizzle said:
so in your infinite wisdom, under $1000 new, what would you recommend?
Maybe it's an economy of scale thing but I can't see how This Specialized has gears, a nice Sus fork, Avid Juicy brakes and a really nice frame and only cost $100.00 more than that Kona, oh and it weighs just under 28lbs per MTB UK mag.
Don't be a sheep
A Rigid singlespeed that cost $1000.00 should not weigh 27lbs...period, those frame fork combo's have to weigh a ton, either that or the components and wheels are made of lead. My cobbled together singlespeed with a boat anchor Manitou Black Sus fork and USE suspension seatpost weighs in the 23's with a friggin 750g freeride tire on back.
My point is, I think the consumer is being taken for a ride (pun intended :D ) with these bikes just because it's the new cool thing.
EXORCIZE
Apologies for continuing a possibly OT sub-thread, but I would just add that if indeed the makers of steel SS 29er bikes are making far more profit than those of a hardtail alum 26" bike (I kinda doubt that considering the extra cost of a steel frame and more R&D for a new product), I don't see how this impacts the consumer, who, in wanting a SS steel 29er, is not shopping for an aluminum 26" bike. A consumer should determine value in accordance with his own needs/desires and the available products that can meet those needs, and without contemplation of resulting corporate profits, which is besides the point.
1 - 20 of 26 Posts
