YES.Alpenglow said:Anyone know if the 06 Z1 light lowers will work with an 05 Z1?
These are my 05 lowers on my 06 Z1 Light ETA.
....well, that one's a bit different. I would wait until it can be verified as the lowers for the AM are redesigned for 06 (validated by new post mounts). If they went the way of the 05 AM 1 (110-130mm), they will not be compatible. If you don't need the "on-the-fly", pre-set compression adjustments, I would recommend getting the Z1 Light ETA. Better over-all compression damping cart IMHO. Essentially the same as the 05 Frankenforks otherwise.Alpenglow said:I am guessing they will, But i'd like to be sure. Thanks
[/QUOTE]Alpenglow said:I am hoping to be able to get white Z1 Light lowers form Marzocchi. Does anyone know how much the lowers cost?
EDIT: If you meant, "will the 06 Z1 lowers fit an 05 AM 1 (130-150mm)...then the answer is yes.
