Hi all,
I have a 1998 Tacoma 2wd with the little 2.4L engine with about 140K on the odometer. This Summer I put in a K&N filter and new plugs, PCV. The mileage went up to 25-6mpg. I was so happy, I wasn't even hypermiling. Well now that it is cold my mileage has dropped to around 18.5-19mpg. :madman: For gas I use 87 octane from BP. Since then, I have put in a bottle of Gumout complete fuel system cleaner http://www.gumout.com/ourProducts/ReganeFSC.asp because the guy behind the counter said it was ~10X stronger than Lucas which I had previous experience with. At any rate, it still is not getting more than 19mpg. Of late, my wife has been driving it to work only ~5 miles each way and the short trip may be having an effect on the mileage as well. Here are my thoughts.
1. I got some bad gas, or the Winter gas with Ethanol is sucking the life out of my truck.
2. I have a clogged fuel system, but I thought that the additive would have helped by now. I don't remember doing the fuel filter, so it is a likely culprit.
3. My wife needs to drive it hard once and a while to blow out the injectors.
What do I do? Put in a tank of 93 Premium to see if the mileage improves? Try another additive, Seafoam or BG44K? Obviously, I will be changing the fuel filter as soon as I can.
Thanks in advance,
B
Thanks in advance,
B
