Bottom Brackets, Headsets, and Hubs as stated?
Or do you use it on other things as well?
What do you use it for?
What do you have stock in the company? Take it easy on this stuff you don't need that much.sasquatch rides a SS said:if you have a white frame it will permanently stain the frame a greenish-brown color wherever the grease sat on the frame for awhile. I've had 2 frames stained by this near the seattube and bottom bracket.
LBS fault when they built the bikes, happened before I got them. Since they were special order I manned up and bought the bikes as-is to save the hassle and multiple week wait.ChainChain said:What do you have stock in the company? Take it easy on this stuff you don't need that much.
