jennasdad said:
Yeah, I would prefer a polished frame but I'm not up for that much work. I just want to clean up the paint for now.
If you would like to have your frame polished, here is how to get it done.
Send the frame to be chemically stripped. Olympic powdercoating in Santa Ana CA can do that. Talk to Mark Cherry(714) 979-2720
Then send your frame to Bush Metal Polishing in Garden Grove CA to be siceled. Talk to Dave Bush
(714) 537-7440
Then send your frame to Custom Metal Finishing in Gardena CA to be ball burnished. Talk to Rosie. (310) 532-5075
This will make your frame nice and shinny!
Now, simple polishing of the frame will deteriorate over time as the aluminum is essentialy a raw state and has no protection from the elements. We have only done it a handfull of times in the past but feel it would be a good addition if you are going to take the time to have your frame done. Clear anodizing the frame would give the frame a layer of protection of becoming a dull finish over the years. Custom metal finishing can also help with that. By no means am I making any sort of guarantees to the process above and it would be wuite possible for a frame to be ruined in nearly any step above. It has been very rare for us to have any trouble in the past and the reason we recommend these vendors. They are some of the best we have ever worked with and continue to provide great service.
Good luck on your quest to the shiny bike. I would estimate each step of the process would take about 1 week, but could be longer depending on the work load of any particular vendor.
Casey
Turner Bikes
