Anyone have any thoughts on what to use to get the spots that develop on the polished Spider frames after a while from sweat, mud, rain etc. I have tried blue magic and it helps a little. Maybe I need to give it some more muscle and/or time?
I have a Tracer. It came as "ball burnished", not smooth as polished frames. I took the frame apart and polished it on a wheel and polished out the rough ball burnished surface.Ball burnishing makes the surface harder and makes it resistant to scratches. After a while aluminum gets dull. If you have either finish, it will dull out. You can buy some liquid polish(metal) at a grocery store. It chemically polishes the surface and removes the "dull" look right away. Scratches can be removed with polishing or rubbing compound (auto paint finish). I touch up my frame with the liquid polish and it looks new again. If I really wanted to take it apart again, I could polish it up like new(it takes about a day) on a polishing wheel and polishing compound. The touch up method works fine. On the comment on clear finishing. I tried clear coat(spray) on a polished fork and it dulled and looked bad after a while(you can't repolish it). I also had a powder coat clear on a frame, and it dulled with no way to repolish it.majed said:Anyone have any thoughts on what to use to get the spots that develop on the polished Spider frames after a while from sweat, mud, rain etc. I have tried blue magic and it helps a little. Maybe I need to give it some more muscle and/or time?
