1 - 4 of 4 Posts
Hi guys I was hoping someone could help me to make a decision between these two bikes. I have been deliberating for some time over these two setups and still am not anywhere close to a decision. I love the color of the Trek Cobia ( red and white) but feel the frame is inferior to the specialized. I think the Specialized has a better frameset but inferior drivetrain ( SRAM v Alivio).
I wonder if I should buy the specialized for $200 more and upgrade the drivetrain at a later date. Or should I save the $200 and upgrade something else on the Cobia?
Trek Cobia Setup
Colours
Chi Red
Frameset
Frame
Alpha Gold Aluminum, butted & hydroformed tubing, cold-forged dropouts & bottom bracket, G2 Geometry
Front suspension
RockShox Recon Silver TK 29 w/Solo Air spring, TurnKey lockout, rebound, custom G2 Geometry, 51mm offset crown, 100mm travel
Sizes
15.5, 17.5, 19, 21"
Wheels
Wheels
Shimano M475 alloy hubs; Bontrager AT-850 disc 29 32-hole rims
Tyres
Bontrager XR3, 29x2.1"
Drivetrain
Shifters
SRAM X5, 10 speed
Front derailleur
SRAM X5
Rear derailleur
SRAM X5
Crank
SRAM S800, 44/33/22
Cassette
SRAM PG-1030 11-36, 10 speed
Pedals
Wellgo alloy
Components
Saddle
Bontrager Evoke 1
Seatpost
Bontrager SSR, 27.2mm, 20mm offset
Handlebar
Bontrager Low Riser, 31.8mm, 5mm rise, 9 degree sweep
Stem
Bontrager Race Lite, 31.8mm
Headset
1-1/8" threadless, semi-integrated, semi-cartridge bearings
Brakeset
Hayes Dyno Comp hydraulic disc brakes
Accessories
Grips
Bontrager Race Lite
Specialized Setup
FRAME Specialized M4SL fully manipulated alloy frame, 29" XC geometry, fully butted w/ smooth welding, tapered head/seat tube, forged post mount 160mm dropouts w/ replaceable derailleur hanger, disc only
FORK RockShox XC32 TK SA 29 SL, magnesium lower, 32mm Cr-Mo stanchions, 1-1/8" to 1.5" tapered alloy steerer, coil spring, TurnKey damping w/ LO & external reb. adj., 80mm travel
HEADSET Integrated 1-1/8" upper and 1-1/2" lower threadless, Campy-style, full cartridge bearings
STEM Specialized 3D forged 6061 alloy, 4 bolt clamp, 7º rise, 31.8mm
HANDLEBARS XC flat bar, double butted alloy, 10º backsweep, 4º upsweep, 31.8mm
GRIPS Specialized Body Geometry XCT Men's, dual compound, Kraton rubber, closed end, 130mm
FRONT BRAKE Shimano BR-M446 hydraulic disc brake, post mount, 180mm 6-bolt rotor
REAR BRAKE Shimano BR-M446 hydraulic disc brake, post mount, 160mm 6-bolt rotor
BRAKE LEVERS Shimano BR-M446, hydraulic lever
FRONT DERAILLEUR Shimano Alivo, 9-speed, 34.9mm clamp, bottom-swing, dual-pull
REAR DERAILLEUR Shimano SLX Shadow, 9-speed, SGS cage
SHIFT LEVERS Shimano Alivio, 9-speed Rapidfire plus, SL type w/ optical display
CASSETTE Shimano 9-speed, 11-34t
CHAIN KMC X-9, 9-speed, reusable Missing Link
CRANKSET Shimano Alivio, 3pc, 9-speed, Octalink spline
CHAINRINGS 44/32/22, replaceable
BOTTOM BRACKET Shimano, Octalink spline, cartridge bearing, 73mm
PEDALS Alloy 1pc. body and cage, reflector kit, 9/16"
RIMS Carve Disc 29", alloy double-wall, sleeve joint, 32h
FRONT HUB Formula disc hub, alloy 7075 axle, high-low flange, double-sealed cartridge bearings, machined disc mount and flange, QR, 32h
REAR HUB Formula rear disc hub, cassette, double-sealed loose ball, polished races, machined disc mount and flanges, 19mm contact, QR, 32h
SPOKES Stainless, 2.0mm (14g)
FRONT TYRE Specialized The Captain Control, 60 TPI, 2Bliss Ready, aramid bead, dual compound, 29x2.0"
REAR TYRE Specialized The Captain Control, 60 TPI, 2Bliss Ready, aramid bead, dual compound, 29x2.0"
INNER TUBES Presta valve
SADDLE Specialized Body Geometry Carve, steel rails, 143mm width
SEATPOST Forged 6061 alloy, 2 bolt head, 27.2mm, 12.5mm offset, micro adjust
SEAT BINDER 31.8mm, forged alloy, extruded QR leve
Rockhopper Expert
I have tried both at my LBS the Specialized lighter and had a better frame, the Cobia felt better to ride and had a better fork, but was heavy 30lbs. Cobia was cheaper too.
My quest continues as I have not decided yet.
1 - 4 of 4 Posts
