1 - 6 of 6 Posts
Looking at the Push site, I am seeing the Pivot Kit for Turners at 32.95.
Now I want to be sure it says for that price you get the bushings and the seal kit.
So I get the red things(seals) plus the bushings, err journal bearings? Is this correct?
I tried calling Push but no one answered, I guess everyone is on vacation. So I turn to you guys for the answer.
PS - in case Push sees this, is there anyone in the office to take orders?
Discussion Starter · #3 · (Edited)
Hmm, I just ordered.
Spoke to the rep on the phone. Asked if this included the "journal bearings", they said yes.
Welp, either way I don't think anything needs replacing, but going to do it anyway, I figured why not.
That's because journal bearings = bushings = red things in picture ;)
Moosehead
RK, the Push Bush Package gets you both the red journal bushings and the black seals (flat rubber o-rings). You will re-use your torx bolts and pivot shafts. Also a good idea to get a longer handled wrench on the torx bolts to prevent bolt and/or knuckle strippage.
Also check out DGC's recent threads about the Enduro needle bearing kit for the shock mounts - replaces the DU/reducers.
Discussion Starter · #6 ·
Thanks for the clarification.
OK then, I was confusing journal bearings with the pivot shafts.
And moosehead, I will definitely be doing that needle bearing upgrade. The bike is receiving a big time refresher in January.
1 - 6 of 6 Posts
