1 - 3 of 3 Posts
viva la v-brakes!
I recently got a WI Eccentric ENO hub. I didn't have the WI tool, so in order to remove the freewheel I had to take the hub apart to use my ACS freewheel tool. I put the hub back together and now there's a bit of play. WI suggests tapping the bearing in, my LBS suggested tapping on the axle ends and cranking hard on the 4mm bolts. I tried all three of these techniques, and there's still a little play. Not a lot, but there was zero before I started.
Does anyone know how to eliminate this bit of play, or is just a bit of play normal?
Hairshirt Rider
Is the play at the axle (you can move the axle up/down or side to side), or is the play at the rim when the wheel is bolted to the frame?
If it is symptom #1, the WI suggestions should work.
If it is symptom #2, the play is in bearing. I've had this problem before. Live with it or replace the bearing.
1 - 3 of 3 Posts
