Consider the VP Harrier. In the Altitude version it's even more light weight.Can anybody attest to the durability of HT's newer Evo+ bushing system? I wanted to give them consideration for a lightweight all Mtn build, and I love the stealth black look, but have my doubts regarding the maintenance needed to keep them running smooth. Reasonable price too, unlessninget Ti axle.
Other lightweights I am considering are the Spry and Vault Mag Ti. On the Sprys, I'd most certainly swap in some grub screws with loctite...thinking that would solve the grip issues people have, and I dont much like the glossy black and gold look for my build...but price is right. For the Vaults, I don't love the gold/black look, but could ditch the gold pins and be okay...and I'm guessing the concave grip/feel would be better than others mentioned here, at cost of more rock strikes and $$.
I currently run the ME03s. I'm not sure what makes the Evo bushings different than any other bushing. That being said, they good, grippy pedals that are lightweight. They seem to be sealed well if you ride in the wet. Not as grippy as Oneup aluminum (which are crazy) but still good. Magnesium bodies can get beat up by rocks but so far the ME03s are holding up well.Can anybody attest to the durability of HT's newer Evo+ bushing system? I wanted to give them consideration for a lightweight all Mtn build, and I love the stealth black look, but have my doubts regarding the maintenance needed to keep them running smooth. Reasonable price too, unlessninget Ti axle.
Ran the sprys for a while. I even replaced the pins with their split tips and the traction wasn't enough. They just don't have enough pins IMO.
Be cautious going with titanium spindles unless you are very light. Most ti pedals have a weight limit, usually well under 200lb.
Cool. Just a high number of reviews on vender websites and so forth complaining about having to rebuild frequently, so that was/is making me skeptical.
And fortunately I weigh only 150lbs and dont do big air/drops like I used to, so ti should be no problem...
It's down to the Vault Mag Ti and ME03 (or ME03T) now.
Edit: HT is out. Buddy was just telling me how much he liked them, but needs to rebuild. No thanks. Ha
How many miles do you have on the ME03s? I have a few hundred on mine and so far-so good.Well, not shocked but a bit bummed...the HTs already feel like they need a rebuild. They sure are light...just not sure if the weight savings is worth the "roughness"...feels like metal on metal.
For anybody not counting grams, the Diety Bladerunner is a much better alternative for a thin flat pedal.![]()
Sent from my SM-G960U using Tapatalk
Yeah, I probably have about the same.How many miles do you have on the ME03s? I have a few hundred on mine and so far-so good.
try the Canfield Crampons.....they last and lastI went back to my meo3 because i had wanted a thinner pedal to counter the low bottom bracket. Grip is decent, has NO feel, and the aluminum puns don't last at all. It also developed a creak. Im going back to the tmacs. Its just more enjoyable and sure footed despite the weight. Im interested the the vaults but at this point after having tried so many pedals, the tmac is the way to go and the oneup composites are the best bang for the buck.
Sent from my SM-G973U using Tapatalk
+1try the Canfield Crampons.....they last and last
+1 on the DMR vaults grip like a mofo and pins are easy to replace.The HTs have nice bodies and CNC work on the aluminum but the bearings are tiny and blow up. They're def. disposable and if you're looking for a platform pedal, try to find a pedal/brand that offers rebuild kits easily readily available online. I like DMR Brendogs for that reason - the DMR kits for pins and rebuilds are all over the place so you're not left stranded.
The same cannot be said about other boutique pedals. If you're looking at HT you can pretty much get equivalent disposable pedals on ebay for $30-40, same build and anodization with an OEM generic name.
If you're looking for composite plastic pedals (the value is decreasing due to the amount of alloy equivalents available) check out the review off-site MTBR at Gravel Bike. It's a "$50 pedal roundup:"
https://www.gravelbike.com/50-flat-pedal-roundup/
right back at you.......facebook has ruined everything+1
SMT, there's a name I haven't seen in a long time! Hope all is well man.
AMEN to that Bro! Good to see you on here! The pins... not so much tho (as with any flat pedal). I checked mine last night and half the pins were gone, LOL! Still kept me on the pedals tho!!! There is not a better pedal on the planet and that is just absolute fact.try the Canfield Crampons.....they last and last
