1 - 5 of 5 Posts
Alright, looking for a creative idea here I was doing a normal frame breakdown, clean, repack bearings, etc. I found one of the plastic black washers (cone shaped, black, between pivot axle and outer bolt) and I cannot seem to pop it out. I tried the normal ways I get them out, flipping the bolt backwards putting the head in and hitting it from different angles and usually they pop out easily. I suspect this one has some loctite contamination that is perhaps contributing to it getting stuck. I also took a bolt, dremeled it down, and put the head of the bolt behind the back face of the washer and still could not yank it out. I appreciate any ideas!!
Sent from my XT1585 using Tapatalk
Simplest way to solve this is to remove the allen bolt then put it in backwards with the threads facing. Then tap it with a rubber mallet and the plastic portion will pop right out.
1 - 5 of 5 Posts
