So I assume you have 5mm allen head bolts, and not torx t40 bolts? What sort of allen broke? The ONLY thing I would use to loosen or tighten pivot bolts would be a high quality, snug fitting bit for a socket set, and use a nice long socket driver (and even with a cheater bar- I use an old flat handlebar
) to carefully apply pressure. Use both hands; one on the socket head to keep the bit lined up squarely with the bolt, and the other at the end of the driver arm. Even the most recalcitrant bolts have come free this way. When assembling with blue loctite, I apply it sparingly (one drop) to the threads. It does not take much to keep the bolt from backing out. I would only reassemble with t40 torx bolts. Turner should be able to send you some free of charge. I personally would never want the 5mm allen bolts on my bikes again. I never stripped one but it seemed dicey a few times.
Good luck. Let us know how it comes along.
