I just built a Pivot Mach 6 Carbon and when I went to I stall the final piece (MRP 2X chain guide) I ran into some issues. Because of the low bottom bracket and the chain stay being lower than normal, the chain guide plate would not mount to the ISCG-05 mounts without the roller laying on top of the chain stay. No amount of spacers would work because it is a press fit bottom bracket. I am waiting word from Pivot for a recommended chain guide that is compatible. I wanted to put this up here and some pictures so anyone who is going to build one and plans on using a chain guide should see this first so you won't have to return it as I did.
