The shell is 92mm wide and uses a pressfit BB but not a BB30 setup. Other than Shimano you could use a RaceFace Next or similar crank. If you really want to go nuts then there's always XX...
BB30 on a Pivot design would be impossible. It wouldn't provide enough real-estate for welding and linkage...MTBOaxaca said:Pivot should use a BB30 then any crank can be run!
