1 - 8 of 8 Posts
So after a search with not much info to be found, do any of you have any experience with these racks? I want a rack system that I can use with three bikes and not have to remove the front wheels off. After researching this method looks to be the most promising. I just want to hear real world experience. I really want to know if this system will touch the rims or spokes?? I will be running tires in the 2.35-2.5 range so wondering how the fit will be. Here is a pic and hopefully this thread can shine some light on this rack system.
I posted this up in car and bike with no luck so thought I would try here.
A similar type of rack is the WheelWally. It fits all tire sizes because the wheel mounts to the side of the rack (not into slots) and it is actually "attached" to the wheel so the front wheel of your bike won't bounce up in the air when you hit bumps.
Be careful with any of these racks though because you may only get 2 bikes to install easily. As was pointed out, handlebars can cause interference.
WheelWally - Truck-Mounted Bike Rack - Wheel Attachment System
1 - 8 of 8 Posts
