Yes, I run it mullet style and it is a short 42mm offset lyrik ultimate. What a absolutely phenomenal bike it is... I have a fairly large stable of bikes including a Wreckoning, and a Following and this is the bike I seem to always grab and have beaten every one of my PR's set on others bikes with the Moxie...amazing bike....Amazing!
Hi again!
Very interesting setup you got there. I also see you got a very short stem and a hi-rise handlebar. Would you mind giving some more info on your setup, i.e. tyre sizes front and rear, rim sizes front and rear, travel on the lyrik, stem length, handlebar rise and width, crank arm lengths, seatpost travel etc. Also, are you running the long or the longest?
I own a long Moxie MK1 since April, I am running it full 29er, 2.35 Magic Mary supergravity front and rear. The only tyres that would survive... Also running a 51mm offset DVO diamond @ 140mm travel that I am looking into replacing with a short offset fork that will be also able to take a larger tyre up front. Cockpit is 38mm stem and lo-rise 760mm handlebar, without spacers under the stem. This gives me a very aggressive riding position and good traction up front however I am having a lot of pain in the neck trying to look far ahead on the trail when going downhill... Crank arems are 170mm. Although trying several stem heights by adjusting the spacers, I feel that something is wrong in the setup...
Thanks in advance for the info!!
