1 - 4 of 4 Posts
I have a 2017 27.5 boost Pike with FAST 3-way damper. I'd like to go up to 170/180mm travel with a lyrik/yari chassis. Is it possible to transfer the FAST pieces over to a lyrik damper?
The different top cap size/threads seems to be one potential issue, but I think the boost Pike top cap is the same size/thread as the Lyrik?
Other than that, what other parts are different between the Lyrik and Pike dampers? Longer bladder and damper shaft?
Formerly PaintPeelinPbody
BUMP
lets say you were building a fork from parts: could you use a Pike damper (cartridge and rod) on a Lyrik/Yari?
Likewise, could you use a Pike air spring rod in the Lyrik?
I would assume that so long as you dont exceed the Pike's travel (140mm) you'd be fine. Obviously the Pike/Rev internals would be too short to extend to cover the Yari/Lyrik's 170mm (29") max travel.
1 - 4 of 4 Posts
