DLine said:
I used to use a magnet to remove the balls and springs on my Psylo - the alternative is spending an hour on your garage floor with a magnifying glass.
Jeez guys it aint rocket science!
Take the fork off the bike.
While holding it straight up take off the Uturn knob.
Cup your hand over the balls and spings, flip fork over, they all fall in nicely. Otherwise put a towel down under you so they stick rather than bounce away.
I've removed mine like 5 times and not once lost a ball or spring.
Another trick. Don't pull the spring out with the fork vertical. Secure the fork horizontal with the ground in a vice or bike stand. THEN remove the Uturn spring. I guarantee you won't lose any oil if the fork is flat. You don't need to change it on a new fork. Likewise, when you do change it, just point it down to drain and then put it back to level to refill it. It won't be messy that way. The lower chamber is large enough for the 15cc that it won't spill out the lower mounting hole when filled.
It's really so easy, that even our president could figure it out!
BTW, make sure to LUBE that sucker up really good with silicone engine belt grease from an autoparts store.
Anyone had to pull the damper rod out from the lowers yet? Mine seems to be stuck and there's not really any solid piece inside the shaft to pound on like the Uturn side. Any suggestions? I used a hammer and nail to get the uturn out because it's solid steel bar. The damper side has a delicate rebound shaft inside it so the hammer and nail wont work. It's in there pretty damn good too.
