Ok, I'm a slave to my Hopeys. One of the real bummers when seeing the Pikes was that RS decided to shove a fat plug in the bottom of the steerer tubes with just a tiny 5mm threaded hole. To install a Hopey you need to be able to slide a 12mm socket in the lower end of the steerer tube to tighten the Hopey's expansion fixing wedges. I had to mill my 12mm down to get it in the bottom of my Z1 FR1, but there was no way I could get it in the Pike.
I decided to epoxy a 12mm 1/4"-drive socket to the Hopey fixing nut and so eliminate the need to insert anything fatter than the 1/4" socket extension into the fork from below. I bought a 6-sided 12mm socket and cut it down to the bare minimum size to save weight (22g total for the nut now), and JB Welded it on the Hopey's fixing nut:
The problem was that I only had a 6" extension, but needed one about 7" long, so I decided to make one. I bought a 12" drill bit extension for $5, cut the head off, and with a flat file I milled the end to the same size as a 1/4" socket head:
On the other end, I found a non-metric 1/4" drive socket I would not need that the shaft fit into, and glued it onto the other end of the saft to make a 10" long 1/4" socket extension:
The shaft was exactly 1/4" in diameter, so I had to enlarge the 5mm hole in the steerer tube's plug by a tiny bit which I did with a 1/4" drill bit. I then gave it a few passes with a round file so that the custom socket extension would slide smoothly:
Now with the Hopey in the steerer tube I just have to slide my socket extension up through the plug and I can snug the little booger down:
It's easy, umkay, children?
.jpg)
.jpg)
