PIKE Experts roll right up!
So I had a ride on a PIKE 454 Uturn yesterday nice fork and I'm looking at putting one on my Spot, I currently run an AM1 which is awesome but lacks a 20mm and A2C a little high me thinks, want a little better balance.
Anyways pos chamber started at 110 psi neg chambr 90psi
Fork was stiff but not supple esspecially compared to AM
Stroke was smooth though.
Reduced POS chamber by 10psi and improvd slightly!
I no my AM1 inside and out so I don't think the fork is worse just not setup as well as my AM1.
Thoughts as to what PSI settings in POS or Neg, Ive read on MTBR differing opinons on wether POS and NEG should be same or Neg should be 20% more than POS and v vs sa.
Cheers for input I want to be sure Im doing the right thing before plopping down my $$ as AM is not bad just not 100% optimal all the time I think its possible to get the same suppleness on small stuff and have the 20mm stiffness benefits and also the balance though I don't want to go to steep in HA so I wouldn't go less the PIKES A2C for my trail riding fix.
