1 - 5 of 5 Posts
I just recently got a Pike, and I had been running a 6" Z1 previously. I had an 8" disc rotor up front, and when I put on the new fork, I tried to install the brake on it. Turns out the adaptor I was using was too wide. Nobody at the bike shops 'round here know anything about the Pike, so I was wondering which specific 8" Hayes adaptor I need. Thanks.
No, that's not phonetic
Zoke, for whatever reason, places the IS caliper mount outboard 6 mm on their 20mm thru axle forks. Normally you would put 6mm of spacers between the fork tabs and the caliper on a Zoke to get things lined up, but it sounds like Hayes has an adapter which does the job in one step. So the suggestion that Hayes makes a more standard, thinner adapter makes sense.
1 - 5 of 5 Posts
