1 - 3 of 3 Posts
What is the minimum travel you can set a Pike Air to? I've seen 130mm on the alltravel model and 110mm on the U-turn. I need around 90-100mm to go on my Racer X for endurance racing and xc but really like the maxle idea for stiffness.. Thanks
If you get the U-Turn spring version, the min travel goes down to 95mm - shorter but definately heavier than the air!
Depending on how many travel spacers you install, you can set the fork at whatever travel you want.
I have a Pike Dual Air set at 100mm on my 4X bike. It just required installing 40mm of spacers on the air shaft inside the fork.
1 - 3 of 3 Posts
