1 - 6 of 6 Posts
Just posted about coil or air for a Pike fork on the appropriate forum however have a vague recolection about something to do with rockers for the 05 spot needing changed to accomodate this fork. Sure I posted about this before but cant seem to find the post or answer.
if memory serves me correct I should be able to get away without changing anything (since the rockers are no longer available) and an air of Coil 454 would be the best choice.
Or any other suggestions for a travel adjust stiff fork to replace my Maverick DUC?
Cheers
** How to I delete this? - just found the old post, looks like I should be ok with te 454, just to get last years air or this years coil (no longer do Air in 2009 on the Pike) ***
Discussion Starter · #6 ·
think I found a pair at active cycle, in the post now. woopppee :D
Now to work out wht stem I need, gonna order a hope hub and cut the spokes and remove my xm rim from the Mav hub...tata Maverick
1 - 6 of 6 Posts
