'06 MKIII pike 454 u-turn / Noticed when airing up the fork negative chamber that oil is coming out of the schrader valve upon un-screwing the shock pump. Repeatedly tried to see if may be it was only a small amount but seems to keep coming couple of drops or more each time. Do I have a problem? Only two weeks old! Also is it neccessary to check the pressure each time I ride, which is daily?
