Negative pressure can't be "higher" than positive at full travel
My neg is 5-10 psi less than pos psi. Just keep dropping the pressures, and keeping the stantions lubed and you'll figure it out. Give it a chance to break in the seals a bit too (10-20 hours).
The physics of the Pike air set-up with pos and neg chambers dictate that if the pos air is set up first, and then the neg is pumped up, if you surpass the pos pressure you just set, then the pos chamber will simply begin to compress. Basically, you can't put more pressure in the neg than the pos...they just equalize. This is why people are saying that 5-10 psi less in neg than pos gets plushness without travel loss.
BTW - The manual I had in for my '06 listed pressures way to high.
-kcav
