Installed a rs charger 2.1 RC (00.4020.170.000) in my ‘18 yari rc 29+ (FS-YARI-RC-B1) 170mm. The fork is specd withe the debonair air spring. The damper rod is 10mm longer than the air spring rod. I noticed the spring rod was stamped pike 29 160mm. Did RS PUT THE WRONG AIR SPRING IN? Will try and call them tomorrow to see if this is a problem. I was told the charger damper was the correct application. Anyone el se seeing this?
